Fabric Duct Modeling
Old   June 30, 2008, 16:00
Default Fabric Duct Modeling
Dan
I'm trying to model a fabric ventilation duct that supplies air to a room through a porous fabric.
I have two scenarios I'm trying to represent: 1) modeling the flow inside of the duct with a vent outlet to represent the fabric strip (outlet).
2) The same arrangement as in 1), but now the dcut is discharging to ambient air, and the fabric strip is represented by a porous jump. (The computational domain in this case is the entire room that is being supplied by the duct.
In practice, the pressure is supposed build up in the duct and then flow through the fabric giving an exit flow that is normal to the fabric surface and relatively uniform down the length of the duct. What I'm seeing in the simulation is a fast escape of air from the start of the duct that decreases along the length of the duct.
I've looked at loss coefficients that increase until the solution diverges, but I'm not getting the duct to pressurize properly. I'm using a polynomial dp = k 1/2 rho v**2, and I have no real data to compare this to,so I'm using estimates from perforated plates assuming a thickness of 5 mil.
Is there another way to characterize the loss through the fabric, and is there a way to force it to be normal to the outlet surface?
Old   September 27, 2024, 04:43
venu
Venu Angirekula is on a distinguished road
Hi Dan,
Any update on this, Did you now understand how to model the fabric ducts? Per our understanding, the flow rate of nozzles will decrease from duct entry to end.It won't be same for all outlets(nozzles) along the duct
Venu Angirekula is offline   Reply With Quote
Duct Flows Haroon Junaidi FLUENT 0 April 14, 2008 08:21
turbulent modeling with wall functon(or modeling) yoo seon oh Main CFD Forum 5 July 4, 2007 15:06
flow through duct N. Natik FLUENT 3 January 9, 2006 09:15
3D duct Muhammad zubair asif FLUENT 1 July 10, 2004 19:01
Duct Flow omar Main CFD Forum 4 December 9, 1999 13:43
