read file in UDF
Old   June 24, 2008, 12:05
Default read file in UDF
Echo
Hi guys, I need to read some discrete data from a file for all the cells in the domain. Do you have a UDF which can do this or could you please tell me how to achieve this.
thanx
Old   June 25, 2008, 02:46
Default Re: read file in UDF
Rami
Hello Echo,
Here is an example extracted from my UDF, where I add convective heat flux at certain coupled wall zones.
The input file, named fin-9.inp, is
__________________________________________________ _______________
10 3.42 300 .01 ! id, HTC, Tamb, thick side-mi v-wall (metal) 23 3.42 300 .01 ! id, HTC, Tamb, thick side-mi-shadow v-wall (air ) 12 12.14 300 .01 ! id, HTC, Tamb, thick top-m h-wall (air ) 25 12.14 300 .01 ! id, HTC, Tamb, thick top-m-shadow h-wall (metal)
and the relevant part of the UDF that reads it is
#include "udf.h" #include <stdio.h>
float HTCv[100], Tambv[100], thickv[100], HTC, Tamb, thick; int id; char line[80]; FILE *finp, *fout; /* declare file pointers */
DEFINE_EXECUTE_ON_LOADING(report_version, libname) /************************************************** ****************** UDF called on loading of libname ************************************************** *******************/ { /* identify UDF version, function entry print and input echo */ fout = fopen("fin-9.out", "a"); /* open fout for append */ fprintf(fout, "report_version:\n\
***** external convection on coupled walls - udf-9.c of 23/06/08 *****\n\
open file for writing\n");
/* read input */ finp = fopen("fin-9.inp", "r"); /* open finp for read */
while( feof(finp) == 0 ) /* read until EOF reached in input */ {
fgets(line, 70, finp); /* read 70 characters */
sscanf(line, "%d %g %g %g", &id, &HTC, &Tamb, &thick);
HTCv [id] = HTC;
Tambv [id] = Tamb;
thickv[id] = thick; } fclose(finp); /* close finp */ fclose(fout); /* close fout */ }
NOTE: Being an absolute beginner in C, I am sure that the coding is extremely clumsy, but it works fine, and you can get the idea and improve the coding.
I hope it helps, Rami
Old   June 25, 2008, 11:58
Echo
Hi Rami, thanks for your reply. My actual goal was to use the read data for initialization of a UDS. I wrote the following UDF for this purpose but it doesn't work. Do you have an idea where the problem arises from?
#include "udf.h"
DEFINE_INIT(my_init_func,d)
cell_t c;
Thread *t;
real xc[ND_ND];
FILE *file;
real numbers[800];
int i,j;
file = fopen("fscanf.txt", "r");
i = 1 ;
while(!feof(file))
/* loop through and store the numbers into the array */
fscanf(file, "%f", &numbers[i]);
i++;
fclose(file);
/* loop over all cell threads in the domain */
thread_loop_c(t,d)
j=0;
/* loop over all cells */
begin_c_loop_all(c,t)
j=j+1;
C_CENTROID(xc,c,t);
C_UDSI(c,t,0) = numbers[j];
end_c_loop_all(c,t)
Old   June 29, 2008, 03:41
Rami
As I already said, I am a beginner in C (and also quite new to FLUENT), so I cannot be of much help in debugging. I suggest you add details to explain what you mean by "it doesn't work" so others may help.
Old   July 4, 2017, 13:37
asc
Sri Charan Akula
asc is on a distinguished road
Hello Echo.
Did you find out how to make your udf work?
asc is offline   Reply With Quote
using UDF to read file Ellen FLUENT 5 November 25, 2008 18:38
How to read a file from a macro StarCD Siemens 2 July 8, 2004 22:31
Why I can't read one external file? Lee Siemens 7 April 2, 2004 13:25
Read file RBM FLUENT 0 July 14, 2002 14:48
Read data file R.B.M FLUENT 0 July 11, 2002 00:16
