a problem about dynamic mesh
Old   June 24, 2008, 02:19
Default a problem about dynamic mesh
satum
recently I'm doing a simulation about using dynamic mesh,after complieing the UDF function,when I click Load to load the user-defined function library that Ijust compiled,the Fluent told me that : Error: open_udf_library: system didn't find the specified documentation
Error Object: ()
I don't know which step was wrong pls help me thanks!
Old   June 24, 2008, 18:11
Default Re: a problem about dynamic mesh
Wissam Sakr
Hi Satum, Well i went through this problem when trying to compile a UDF.
I solved it as follows: First i installed Microsoft Visual Studio 2008 Second i went to My start menu --> Fluent.inc products --> fluent6.1 --> Set environment and accepted to modify environment. Third i opened the microsoft's visual studio command prompt and run fluent from there.
Hopefully you UDF will work now.
Regards, Wissam Sakr.
Old   June 25, 2008, 02:37
satum
Hi Wissam Sakr, thanks for your suggestion,i have solved this problem thank you
satum
dynamic mesh and udf problem boboroo FLUENT 1 January 20, 2008 22:26
Dynamic mesh problem Alain FLUENT 2 December 19, 2006 15:46
Dynamic Mesh Problem - please help! Hila FLUENT 0 August 19, 2006 05:19
Dynamic Mesh Problem !!!!!!! CFDtoy FLUENT 3 January 19, 2005 21:17
A problem in dynamic mesh svh FLUENT 2 October 12, 2004 13:50
