June 23, 2008, 08:05 |
Steady state > Transient
When you run a time-indpendent problem in steady state and use the converged solution as an initial solution for the transient solver the residual shoot back up again. As there is no time-dependency in the problem, the solution should be the converged one for the transient case as well so there is no reason for such high residuals. Then for the next timestep the residuals tend to get up again, not as high as the first timestep but still way high. This repeats itself until only after many timesteps the residuals do not increase anymore appreciably and Fluent seems to have agreed there is no time dependency after all. Does anybody know why this is the case and if there is anything one can do about it (for particle tracking I already found using "0 max. iterations per timestep" helpful)? Kind regards |
June 24, 2008, 11:18 |
Re: Steady state > Transient
i also wanna know that
Steady State Vs Transient answers | Kushagra | CFX | 25 | July 23, 2017 03:20 |
transient problem run in steady state | luigi | FLUENT | 4 | March 13, 2008 06:54 |
Transient vs Steady State | Adam | CFX | 1 | April 12, 2007 11:34 |
Steady state transient | hillehillea | OpenFOAM Running, Solving & CFD | 3 | May 26, 2006 18:03 |
steady state - transient | Hilgert Marco | Main CFD Forum | 3 | December 8, 2005 15:52 |
