Periodic boundary condition in 2 directions
Like Tree1Likes
Old   July 25, 2018, 13:23
Pooya Razaghi
pooya_1375 is on a distinguished road
Hi Ethan_Sparkle
I had the same problem. I found that this is possible to be done by CFX. you can define as many periodic B.C.s as you want in different directions with any option (mass flow or pressure) in the interface section
pooya_1375 is offline   Reply With Quote
Old   July 25, 2018, 13:44
Default Periodic flow in two directions
  #22
Pooya Razaghi
Hi everyone I'm modeling an elliptical bank of tubes with a pitch angle of 60 degrees. As it can be seen in Figures I'm modeling a periodic zone with mass flow periodicity in left and right and a zero pressure drop periodicity for up and down. Considering that the flow may change its direction because of the pitch angle of the tubes, the flow may pass through the upper boundary (and also comes in from the lower one). in this condition is "zero pressure drop periodic boundary condition" true?
If not what is the alternative choice for upper and lower boundary condition (because it can't be symmetric due to the geometry)?
Thank's in advance.
periodic boundary condition. jaysree FLUENT 0 December 18, 2007 07:51
periodic boundary condition? Sima Baheri Phoenics 5 October 20, 2007 10:20
periodic boundary condition elyyan FLUENT 4 April 21, 2006 17:30
periodic boundary condition ap CFX 1 March 6, 2006 15:16
Periodic Boundary Conditions in two directions david FLUENT 0 April 1, 2002 08:24
