combustion of single particle enclosed in a box
Old   June 20, 2008, 12:06
Default combustion of single particle enclosed in a box
Andres Reyes
Hello, I am trying to simulate the combustion of a single particle enclosed in a box using fluent. I assumed five faces whit velocity inlet and one whit pressure outlet. The particle is porous. I need see how it is consumed. is this possible? how I can do it? thanks
Old   June 20, 2008, 14:24
Default Re: combustion of single particle enclosed in a bo
Allan Walsh
After doing several similar projects, I don't think Fluent is your best option. Fluent is good for fluid flow and keeping track of enthalpy, gas species, etc.
From the little that you have said, I'm assuming that you will need some detailed models to represent your particle combustion. If you want to implement these in Fluent, you will have to do them as UDF's which means you have to write the code using Fluent's structure and variables which is more time consuming than just doing it as a separate model.
What variables are you interested in? The effect of gas velocity, temperature, and composition on combustion rate? If you change these things as boundary conditions in Fluent, it won't be too exciting since the conditions in the box will likely remain essentially uniform.
Have you considered just writing your own stand-alone code or use something like Matlab or just Excel? Good Luck.
Old   June 20, 2008, 15:02
Andres Reyes
Hello Allan. I need to know the temperature of the particles and the composition. I want to use fluent to compare the results with fortran using a physical model known. thanks
Can fluent track a single (large) particle? Wei FLUENT 8 December 18, 2007 11:43
particle injection at single point drew CFX 2 November 19, 2007 16:01
unable to track particle(single injection) Avinash Kumar FLUENT 0 January 20, 2006 01:04
single particle combustion masoud FLUENT 1 December 15, 2004 11:36
single particle combustion masoud Siemens 0 November 20, 2004 02:06
