Running fluent without cortex
Old   June 16, 2008, 06:48
Default Running fluent without cortex
Sam
Does anybody know if I can run fluent without cortex?
Old   June 16, 2008, 14:15
Default Re: Running fluent without cortex
Renato Pacheco
i think no.
Old   June 17, 2008, 10:09
Chris
Yes you can. From a DOS window (or terminal window), type:
fluent 3d -g
for single precision 3D. You have to make sure the fluent installation directory is in your path (If you don't know how to do this - google it).
Actually, there are many more options you can specify, type:
fluent -help
to get them all.
Old   June 19, 2008, 15:25
Chris (a different Chris)
Cortex still runs when you start fluent with -g, it just uses the text UI rather than the graphical UI.
Which may be exactly what the original poster wanted.
If the cortex process dies or is killed, the fluent process dies too (at least that is the way it used to work...).
Old   June 26, 2008, 12:10
Sam
Yes. Correct. The cortex still runs with -g. I dont want cortex to be running at all but just the solver processes.
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 10:32
PC features for running Fluent Silvia FLUENT 4 October 11, 2006 05:10
PVM running of FLUENT Joe Yan FLUENT 0 February 27, 2006 04:48
Running Fluent Manish FLUENT 2 December 4, 2004 21:18
Running FLUENT 6.0 sims. on FLUENT 6.1 ozgur FLUENT 2 April 2, 2004 14:23
