Constant density on a mixture
Old   June 6, 2008, 05:58
Default Constant density on a mixture
Rémi
I make a flow calculation involving a mixture of incompressible fluids. How can i impose a constant density for the mixture?
I know UDFs enable to handle this problem, does anybody know the code that has to be used?
Thanks in advance.
rémi.
Old   June 6, 2008, 06:17
Default Re: Constant density on a mixture
Victor
I'm not quite a expert in Fluent, but for me the most simple answer it'll be setting to all the fluids in the mixture the same density - the one that your trying to impose - so Fluent will calculate always the same constant density, no matter what you have in that cell.
Or are your looking for something like using a constant density in each cell considering a mean density between all fluids in that cell? If you're looking for that, I suppose FLuent will do it for you (as implicitly said before).
My best regards, Victor
Boussinesq model gives constant density daol FLUENT 4 June 12, 2018 10:28
Specific heat, density evaluation in mixture eqn CFDtoy Main CFD Forum 1 January 29, 2008 03:08
Variable composition mixture .vs. reacting mixture Ting Wen CFX 0 January 7, 2008 07:04
Which solver I should use when density of the fluid is not a constant dbxmcf OpenFOAM Running, Solving & CFD 0 March 25, 2007 05:26
mass density or weight density jaichan Main CFD Forum 0 April 2, 2006 19:45
