June 5, 2008, 21:43 |
Help, Retrieve Flux with Scheme
I want to set my boundary condition based on the outflow flux. Does anybody know how to retrieve the value of flux with Scheme? Thanks a lot.
June 6, 2008, 06:55 |
Re: Help, Retrieve Flux with Scheme
What boundary condition? What flux? Heat fluw? Mass flux? Are you saying you want to set the inlet based in the outlet? If that's what you want, I don't think you could do it - matematically speaking. Unless you have something like: the outlet of the timestep i dependes on the outlet of the timestep i-1. Anyways, I think you probably can retrieve it by a UDF. My best regards, Victor |
June 6, 2008, 13:44 |
Hi Victor,
Thank you. I am simulating a circulating fluidized bed and want to return the solids exiting from the outlet back to the system. I've done it with UDF. Thanks. Tim |
Cannot retrieve file | rayy | Siemens | 2 | January 13, 2007 13:41 |
Flux splitting for WENO scheme | DSS | Main CFD Forum | 6 | January 10, 2007 11:59 |
ENO/Flux limiting/Godunov scheme | Wen | Main CFD Forum | 6 | January 16, 2006 08:06 |
Upwind flux scheme | Biga | FLUENT | 0 | January 12, 2006 13:41 |
Flux at wall boundaries for Roe's scheme | MyG | Main CFD Forum | 3 | February 14, 2004 04:26 |
