linking several faces
Old   June 4, 2008, 10:01
Default linking several faces
Christian F.
Dear users,
I´m trying to link more than two faces for meshing in GAMBIT. If I do so with just two faces, I experience no problem, but if I link three faces and mesh one of them the following happens: the first face is meshed and smoothed propperly the mesh is copied to the next face and is totally deformed (many cells with high skewness) and thus useless As I need the linked faces for periodic bcs and to apply a Cooper scheme for the volume meshing, I would be glad for any hint if there is a limiting number of linked faces or any other restriction I should concider.
Best regards,
Christian
Old   June 6, 2008, 07:29
Default Re: linking several faces
Victor
I don't know if it could help, but try linking the edges instead of the faces... If you have all the edges of a face linked, you should get the same mesh for the faces.
I've never linked faces, as linking the edges has always worked perfectly for me.
My best regards, Victor
Hard-linking faces in Gambit (periodics) Eric R. FLUENT 7 February 25, 2011 02:48
Linking two meshes Geoffroy Chaussonnet FLUENT 3 April 6, 2007 05:59
Problem for linking hsing OpenFOAM Running, Solving & CFD 2 April 19, 2006 05:07
Linking fortran and c vasanth Main CFD Forum 3 January 29, 2005 13:38
linking the script Mavinakere FLUENT 0 September 12, 2002 12:57
