What is the effect of turbulence intensity
Old   May 30, 2008, 15:48
Default What is the effect of turbulence intensity
Beginner
Hey I am beginner with modeling turbulence by fluent I need to ask : can anybody tell me exactly the effect of turbulence intensity at inlet or outlet boundary conditions on the flow variables like velocity , pressure , volume fraction…etc?
Thank you for your answer
Old   June 1, 2008, 07:15
Default Re: What is the effect of turbulence intensity
dsfsd
high ti at inlet will define instability of medium at entry changing heat transfer at surfaces for example or lift drag. TI value at exits is only for situations where backflow occurrs
Old   June 1, 2008, 13:27
Beginner
thanks for the reply. did you mean by stability it effects the occurring of fully developed flow region for pipe flow? should I keep its value at inlet same as outlet? is it have the same effect for the case of iso-thermal flow?
Thanks again
Old   June 6, 2008, 02:35
Rakesh Jha
TI at inlet can be thought of giving some idea about fluctuation in the flow at inlet. lower the fluctuation in velocity lower the inlet TI. We dont have any measure to know the Turbulence intensity, it comes just from guess and experience. Coming to the querry whether to keep the backflow calculations Intensity at Outlet as same as inlet. well if you have a pipe without any ribs/dimples/ etc which can cause intensity to increase during the flow-path then you may apply same, but if your domain is not that smooth then apply based upon your judgement. I can give one example, I had a rib-roughened rectangular channel at the inlet of which the flow was quite normal (Re 30000, TI 5%) but when the flow encountered ribs, intensity shooted up like anything (which was well expected) it went upto 125%. I had the ribs till very near to exit. Now based upon seeing this I can not apply TI at outlet as 5%, It should be somewhere near to 100 or 125% not 5%. Hope this shades some light! Jha
Turbulence intensity?? KC Siemens 0 July 19, 2007 19:41
Turbulence Intensity John FLUENT 2 September 11, 2005 10:15
turbulence intensity co2 FLUENT 2 December 27, 2003 19:41
Turbulence Intensity Tom FLUENT 4 November 14, 2003 10:53
turbulence intensity l.g.patil FLUENT 0 February 8, 2002 13:18
