May 29, 2008, 07:37 |
post processing problem
Dear all, I finish a run and need to do post prcessing work on a zone. for example, make a contour plot at section in the zone. The problem is that how can I get the velocity or gradient(dt/dx or dp/dx etc) in the local coordinate system. would you please give me a hand. Thanks a lot in advance! Charles
June 1, 2008, 12:39 |
Re: post processing problem
display/define iso/surface, line,etc
June 2, 2008, 04:12 |
Thanks for your attention. but the command you mentioned just make a surface from a zone. when doing processing work, the result on the surface is still based on the global coordinate. I need the result based on the local coordinate system. How can FLUENT do this work? Thanks again. Charles
post processing dam break problem | chris wetton | CFX | 7 | February 22, 2008 07:33 |
CFX post processing | zurayk | CFX | 3 | February 15, 2007 09:30 |
Post-processing | Eric | FLUENT | 0 | April 19, 2004 11:17 |
Post processing display problem | Jennifer Haque | CFX | 2 | January 18, 2002 12:01 |
post-processing problem! | joseph | CFX | 3 | October 21, 2001 07:17 |
