Mean Velocity Fields
Old   May 27, 2008, 06:35
Default Mean Velocity Fields
Stephen Smyth
I am wondering if anyone knows if it is possible to produce a mean velocity field over a complete unsteady cycle within FLUENT. I have an oscillating jet moving into a base flow and can capture images at each phase angle. However, the experimental study I am referencing uses PIV techniques to capture a meanflow vector profile. I would like to produce something similar to compare my results against.
Any advise is appreciated
Thanks
Old   May 28, 2008, 03:05
Default Re: Mean Velocity Fields
selvag
hi, after the solution is converged in unsteady, you can run the solution by enabling the data sampling in the iterate panel upto the required time step. After this, you will get the mean velocity field in the contour and plot panels. you can use this for comparison.
Old   May 28, 2008, 06:08
Stephen Smyth
That's great,
Thank you very much for the help.
Stephen
Matching Velocity and Pressure fields Fluent OpenFoam alimansouri OpenFOAM Running, Solving & CFD 0 January 13, 2009 18:51
[OpenFOAM] Average fields jml ParaView 4 December 15, 2008 12:55
UDF for space-filtering 3-D velocity fields Xianmin FLUENT 0 April 11, 2008 21:58
Temperature fields Fernando Lopez Parra FLUENT 1 September 28, 2003 09:15
Velocity Fields/Stream Equations beginner Main CFD Forum 3 February 17, 2003 14:53
