surface tension output
Old   May 26, 2008, 12:45
Default surface tension output
tom
Is there any way to read or output the local surface tension? For example, if I have a udf that defines surface tension as a function of temperature, how can I see what value it is from point to point along an interface?
Thanks
Old   November 19, 2010, 10:09
stulle is on a distinguished road
i have the same problem
at the moment, i try to write the surface tension value to a .text file (with an UDF)
but that also failed
please help
stulle is offline   Reply With Quote
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 04:41
Surface Tension Jim Siemens 0 October 16, 2002 08:33
Surface tension - Continuum Surface Force model Robert Main CFD Forum 0 May 2, 2002 08:34
surface tension in VOF New1 FLUENT 0 April 10, 2002 02:06
[surface tension effect at free-surface ?] name Main CFD Forum 1 September 21, 2001 10:54
