rotating solid zone with heat transfer
Old   May 25, 2008, 14:24
Default rotating solid zone with heat transfer
Sasha
Hi, I'm trying to set up a problem of fluid getting to rotational motion by the rotating cylinder in 3D. Plus, I'm interested in solving heat transfer in the cylinder. So, there is one solid cylinder rotating about its axis, around it there is a fluid zone set to motion due to no slip and there is also the outer cylinder (eccentric to the inner one) which is stationary. Can somebody help me with it. I could not get the things moving. Thank you.
Old   March 24, 2009, 17:55
Felipe Gutiérrez Donoso
Figd84 is on a distinguished road
I´m having the same problem, working with VOF, two phase fluid (water-air) and k-e RNG turbulent model.
Any tip about it?
Figd84 is offline   Reply With Quote
radiation transfer between solid and fluid zone shyang FLUENT 0 August 13, 2008 13:45
Rotating solid zone Rajesh FLUENT 0 May 17, 2008 06:44
Rotating cavity - heat transfer problem AP CFX 1 June 5, 2006 05:01
Heat transfer through solid. Rob Hart FLUENT 5 October 17, 2004 09:59
Solid-Solid Heat Transfer with Contact Discontinuity Jonas Larsson Main CFD Forum 9 September 10, 1999 16:46
