May 25, 2008, 05:50 |
Turbulent viscousity ratio limit
Hi,everey body. I have a question about the report,Turbulent viscousity ratiıo limmits to ------ in ------ cells.I learnt that changing mesh of model sometimes solves the problem,but I don´t know what happens exactly.If anybody know the answer please let me know? regards
May 25, 2008, 12:31 |
Re: Turbulent viscousity ratio limit
The warning means that the FLUENT code gets results of turbulent viscosity for soem cells that are higher than the allowed limit (this can be fitted using solve -> solution -> limits or something like this). This warning does not necessarily mean that you have a problem, however if number of cells with acitve limiters increase from iteration to iteration your calculation will probably deverge. Reasons can be insufficent initialisation, some poor quality cells, insufficiant numerical settings or some complex flow areas.
Regards |
May 26, 2008, 04:21 |
Have a look into cfd-online wiki's Fluent FAQ. I think there should be a note about this issue. this is fairly comman question asked here, if you do search you would find postings about it. (In fact I remember writing a long post about it, so do not want to repeat.)
May 27, 2008, 13:22 |
It was helpfull.Thanks.
About Turbulent Viscosity Ratio Limit... | Fabio | FLUENT | 1 | August 7, 2008 16:40 |
Question about eddy viscosity ratio limit | Piti | CFX | 2 | January 17, 2008 17:49 |
turbulent viscosity ratio | Yijin Li | FLUENT | 1 | May 10, 2007 04:50 |
turbulent viscosity ratio | James Willie | FLUENT | 1 | June 21, 2005 04:35 |
Turbulent Viscosity Ratio | xiang | FLUENT | 3 | May 20, 2003 13:46 |
