UDF in parallel computing
Old   May 24, 2008, 14:54
Default UDF in parallel computing
Shamoon
Hi all,
Hope everyone is fine. My problem is that I want to use a UDF for variation of Unsteady Mach. The problem is big enough that I have to run it in parallel. But Fluent says that you require separate UDFs for host and nodes. I am not getting with this Kindly help me in this regard if anybody had used UDF in parallel before!
Regards
Old   May 24, 2008, 19:09
Default Re: UDF in parallel computing
lurk
i think fluent will find it automaticly. Or else just look in the src folder or a udfconfig-host.h
Old   May 25, 2008, 04:46
Shamoon
Thanks lurk
Actually when I run UDF for Mach on single PC it runs very well. But when I read it on host computer (in parallel) it gives a long error msg that it couldnt find some cortex file or... etc ( i didnt remember exact words ! sorry!).
So should I have to make 5 separate UDFs for 5 clustered computers? What is the remedy?
Old   May 25, 2008, 12:33
BastiL
In general for parallel use UDF has to be parallelised. Communication between different calculation nodes has to be ensured. I have never done this in FLUENT before but it should be described in the UDF guide. Otherwise, ask support for more help.
Regards
Old   May 25, 2008, 15:33
Shamoon
Yeah I know that but for that should i have to write as many UDFs as tha no PCs in parallel?
parallel computing James Main CFD Forum 11 April 14, 2009 05:21
parallel computing Daniel FLUENT 1 November 21, 2007 17:09
parallel computing rui Siemens 0 June 25, 2007 07:18
Parallel Computing Himanshu Almadi FLUENT 0 April 12, 2006 13:43
Parallel computing Himanshu FLUENT 0 January 23, 2006 11:21
