multiple fuels inlets in FLUENT
Old   May 20, 2008, 17:13
Default multiple fuels inlets in FLUENT
cecillia
Are any possibility for me to make multiple fuels inject in FLUENT? For example: coal and wood, both in particles?
Thanks
Old   May 20, 2008, 22:23
Default Re: multiple fuels inlets in FLUENT
Billy
How about set two injections?
Old   May 21, 2008, 13:11
cecillia
Hi Billy:
I need to inject two kinds of different solid fuels from different locations. Do you have any suggestions?
Thanks
Old   May 21, 2008, 14:55
Allan Walsh
Sure, we do it all the time. As Billy said, use separate injections. For example, coal could be Injection-0 which would have a set of particles each with their own type, injection location, particle diameter, combustion properties, etc and wood could be Injection-1, again with its own properties. Good luck.
Old   May 21, 2008, 17:13
cecillia
Thanks Allan. That is so helpful!!
Since I am using oat hulls as the fuel, I guess I have to define a new material right? But how can I set up my parameters?
Old   May 22, 2008, 06:02
Billy
cecillia, I don't know which parameters you are wondering?
Old   May 22, 2008, 12:58
cecillia
Hi Billy: When I define a new material in FLUNET, I have to set up the parameters like conductivity, binary diffusivity, and others. Do you know how can I set them up for a new material in the case that I don't have so much informations? Thanks
Old   May 23, 2008, 05:52
Billy
Hello Cecillia, I don't know how to tell you the detail for it's so involuted. However, the website following, which is FLUENT 6.0 HELP,maybe help you sometimes. http://combust.hit.edu.cn:8080/fluen...ug/node266.htm
Old   May 28, 2008, 15:59
Default fortran code for non newtonian fluid *NM*
shahram
Multiple inlets ploceus OpenFOAM Running, Solving & CFD 1 July 5, 2023 06:45
Multiple inlets problem Jeff Main CFD Forum 2 August 17, 2005 11:48
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 03:29
multiple inlets Bob Haase Main CFD Forum 1 January 19, 2001 21:57
combustion with different fuels Gabriela Peralta FLUENT 1 January 5, 2001 00:02
