Fluid-Zone-depending viscosity
Old   May 20, 2008, 04:23
Default Fluid-Zone-depending viscosity
Dennis
Hello everyone,
I am trying to write a UDF for a Fluid-Zone-depending viscosity. But I am new to UDF and so I am having problems.
To test the UDF I have a simple 3d Model which consists of 3 conneced cubes (size 100mm, 100mm, 100mm). Cube 1 is Fluent-Zone 1, Cube 2 Fluent-Zone 2 and Cube 3 Fluent-Zone 3.
I am using a 2-phase VOF Model. The UDF should change the viscosity of the 2nd phase depending on the Fluid-Zone. IF it is inside Fluid-Zone 1 the viscosity shall be for example 10Pa s, in zone 2 -> 20Pa s and in Zone 3 -> 30Pa s.
Thanks in advance
With kind regards Dennis
Old   May 20, 2008, 05:42
Default Fluid-Zone-depending viscosity UDF
Dennis
I created a UDF which works for me, maybe someone is interested in it, too. So here it is:
#include "udf.h"
DEFINE_PROPERTY(cell_viscosity,c,t) { real mu_lam Domain *domain; domain = Get_Domain(3);
if (t == Lookup_Thread(domain,4)){
mu_lam = 10.; }
if (t == Lookup_Thread(domain,3)){
mu_lam = 20.; }
if (t == Lookup_Thread(domain,2)){
mu_lam = 30.; }
return mu_lam;
Greetings Dennis
Fluid Zone Source of Z Paul FLUENT 0 July 31, 2007 15:55
Zone fluid Pelli FLUENT 2 June 22, 2007 08:58
how to define a local zone in whole fluid zone? Lcw FLUENT 3 September 21, 2004 09:33
Problem in fluid zone!!! STK FLUENT 2 September 1, 2004 16:27
how to change inteior zone into fluid zone zwdi FLUENT 3 March 2, 2004 21:25
