match uds flux value between wall and wall_shadow |
May 18, 2008, 12:29 |
The Fluent automatically divides wall into wall & wall_shadow when wall boundary condition is given between two fluid region.(of course, in the case of interface between solid region and fluid region)
The problem is how to manually match uds flux value between wall and wall_shadow by using UDF since I'm using UDS transport equations. |
October 26, 2020, 23:05 |
Rep Power: 6 |
Hi,have you solved it?
temperature increased does not match the heat flux | GUOQIANGWOO | FLUENT | 2 | April 6, 2010 02:29 |
wall shear stress isn't match by experimental valu | mohsen | FLUENT | 1 | March 8, 2009 06:53 |
match uds boundary condition in wall & wall-shadow | pour | FLUENT | 0 | May 20, 2008 09:56 |
heat flux on fluid-solid interface does not match | Dai | CFX | 4 | October 30, 2006 09:38 |
wall & wall shadow net heat flux | Barbaros | FLUENT | 1 | August 5, 2006 03:00 |
