Half laminar and turbulent model trying to solve
Old   May 16, 2008, 10:56
Default Half laminar and turbulent model trying to solve
Andrew Clarke
Hi there. I am currently dealing with a problem where the fluid flows into a radial gap (laminar flow here - part one) and exits into an axial channel in turbulent conditions (part two).
I have tried solving the full model using K epsilon realizable but the results do not make sence.
I then tried to create the first part of the model in laminar (result on laminar part good) and then created the second part as turbulent using inlet velocity values here from velocities at the outlet of the first part (this is when results go crazy)... can this be done?
If not, is it possible in fluent to solve one half of the model in laminar and the second half in turbulent? Or is there a better solver that can be used for these radial jets entering the turbulent region?
Any suggestions at all on this would be gold to me... many thanks for your time reading this...
Old   May 16, 2008, 18:51
Default Re: Half laminar and turbulent model trying to sol
red lemon
separate fluid zones and define one as laminar (tick box in fluids panel). Turbulence quantities will be transported through laminar zone but no generation or dissipation.
Old   May 17, 2008, 08:00
Andrew Clarke
Many thanks. I will try that. I will post another reply as soon as I get results on the procedure to let you know.
Old   May 19, 2008, 12:52
Andrew Clarke
I have looked in the fluid panel and i cannot find anywhere where I can define laminar or turbulent... I am using Fluent 6.3
Old   May 19, 2008, 14:22
Andrew Clarke
I have now used the command:
define/boundary-conditions/fluid
however there is no sign of a command prompt for deciding laminar or turbulent...
Is this because im not using the new ansys/fluent program or is it possible with 6.3 fluent?
Old   May 19, 2008, 14:40
Andrew Clarke
Ah yes.. got it. I must define the viscous solver overall as turbulent and then the option appears in the command prompt. Many thanks for your direction in help. May the pressure*area be with you...
Laminar-turbulent transition model Vlada FLUENT 1 September 28, 2006 20:51
Symmetry model half or total geometrical model in LES vvqf OpenFOAM Pre-Processing 3 March 22, 2006 10:06
3d half model airplane simulation Loh FLUENT 2 January 17, 2006 23:36
how to model transition laminar to turbulent? james Main CFD Forum 0 October 1, 2003 04:16
3d and half model nikita FLUENT 0 April 22, 2003 04:41
