How to make a wall hydrophilic or hydrophobic?
Old   May 15, 2008, 04:57
Default How to make a wall hydrophilic or hydrophobic?
Kes
Hello i'm using Fluent 6.1.22 and i'm wondering whether it is possible to make a wall hydrophilic or hydrophobic in Fluent.
Old   May 15, 2008, 11:31
Default Re: How to make a wall hydrophilic or hydrophobic?
HP
Wow!!! Difficult question!
You have 1-phase or 2-phase flow? Water is defined as a phase or as a species?
Old   May 15, 2008, 22:49
Kes
Haha i'm using a 2 phase flow with water and oil. The water droplets generated seem to be like sticking on the walls of my structure which is why i'm thinking maybe the walls are set to be hydrophilic. I'm trying to see if there is a way to change this setting or not. One of the forum users bohis said that it is possible to set the contact angle so i'm seeing if this works or not. Any ideas?
Old   February 1, 2022, 06:59
Mohammad iman khalili
M.I.K is on a distinguished road
Originally Posted by HP
;150823
hi
i have a question that how can i simulate a hydrophobic wall in 1 phase ?
i want to simulate a underwater in a water flow and see effect of hydrophobic surface
M.I.K is offline   Reply With Quote
Old   February 1, 2022, 10:48
Lucky
How to use wall adhesion
Then set the contact angle to the suitable wettability angle corresponding to the hydrophobicity of your surface-liquid combination.
Hydrophobic and Hydrophilic Surfaces Nuno L. FLUENT 2 May 27, 2021 02:28
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 12, 2008 00:23
How to make a xy plot of skinfriction or wall shear along a curve sek OpenFOAM Running, Solving & CFD 0 February 20, 2008 14:01
help: how to make use of wall functions when .... xiaofish FLUENT 0 September 18, 2007 22:49
how to make wall adiabatic MMACRB FLUENT 1 January 29, 2007 03:42
