PBM availability.
Old   May 15, 2008, 04:06
Default PBM availability.
Kes
Hello i would like to ask for PBM (Population Balance Model), whether its found in Fluent 6.1.22? If it is, can anybody tell me how to access it?
Old   May 15, 2008, 04:40
Default Re: PBM availability.
bohis
go through manual. You need an extra license for that anyway
Old   May 15, 2008, 04:55
Kes
I have searched through the manual but am still unable to find the function PBM. The manual i'm using is an online manual which is listed as below, http://jullio.pe.kr/fluent6.1/help/index.htm. Please advise.
Old   May 15, 2008, 05:24
bohis
well, it is manual for Fluent 6.1, in that time there was no PBM yet. Have a look to manual of 6.3, maybe 6.2 is enough.
Old   May 15, 2008, 05:27
Kes
However i'm using Fluent 6.1.22. In this case does this mean that i could not use the PBM function?
Old   May 15, 2008, 05:42
bohis
I guess you are right, but I am not sure. I am not used to work with PBM. Are you sure that you need PBM?
Old   May 15, 2008, 05:45
Kes
Yeah i was looking at some forum messages and they were specifying the usage of PBM to solve my problem. Would like to ask you another thing. If i were to create droplets in a T-junction but the droplets created were in the form of slug flow, i shouldn't be using the Mixture model right? Should be using the VOF model right? As there are no dispersed phase. Also any idea on how to make a surface hydrophobic or hydrophilic in Fluent?
Old   May 15, 2008, 06:01
bohis
If the slug flow was going on, I would use VOF. As regards walls your hydrophobic surface, I do not know.However, in VOF you can set the angle between two phases and maybe, you will need to play with stress conditions on the walls. I really do not know
Old   May 15, 2008, 06:15
Kes
Haha ok thanks man.
Old   May 15, 2008, 08:22
Thiru
Hai I could locate the PBM in help mannul. It is clearly saying that we need special licence for that. Here is the exact text from the mannual
1. Introduction
In FLUENT the population balance model is provided as an addon module with the standard FLUENT licensed software. A special license is required to use the population balance module.
FLUENT offers three solution methods to the population balance equation: discretized population balance, standard method of moments, and quadrature method of moments.
Location: /local/Fluent.Inc/fluent6.3.26/help/html/popbal/main_pre.htm
Old   May 15, 2008, 11:19
  #11
HP
In text you go to define models addons and select PBM
Old   May 15, 2008, 22:46
  #12
Kes
I'm sorry i don't quite understand what you mean there Thiru, the address you gave me is for an internet website or what? Plus i think that is for Fluent 6.3.26 while i'm using Fluent 6.1.22.
HP what do you mean by in text?
Old   May 16, 2008, 04:29
  #13
Thiru
Hey Kes. I am sorry for the confusion. It is not an internet website. I just mean the location of the help file which will be created during your installation. When I saw the help files in my local network I could find about PBM. The same path I gave you. Generally it will be the location of help files.
Please let me know if you want those help files (PBM) I can send as an attachment.
Thiru
Old   May 16, 2008, 05:27
  #14
Kes
Haha ok. It would be good if you could send the help files to my e-mail address.
Old   June 26, 2016, 01:34
Default Pmb
  #15
elham
emka is on a distinguished road
I'm looking for PBM in fluent 6.3.26. I couldn't find it yet. can anybody help me?
emka is offline   Reply With Quote
Old   June 26, 2016, 03:46
elham
I get it
on the console type: define models addon-module
then appear a message so enter 5.
Documentation question source availability license brooksmoses OpenFOAM 4 January 10, 2014 14:44
Availability of previous time level values in UDF ranga sudarsan FLUENT 0 September 1, 2008 10:17
Availability of experimental combustion data? Mario Main CFD Forum 3 September 23, 2003 12:05
