turbulence viscosity ratio limited to ........
Old   May 12, 2008, 11:38
Default turbulence viscosity ratio limited to ........
bbb
hi all,
i am trying to model a wing in free air using k-e model. initially there is meaasge for turbulence viscosity ratio limited to 10e5 and eventually the iterations are terminated with AMG divergence : pressure corrections message. any help ?
thankyou
Old   May 13, 2008, 14:33
Default Re: turbulence viscosity ratio limited to ........
Meghnath
hi,
if you are using fluent 6.3.26 version, change pressure cycle to flexible. To change this, goto solve-->multigrid.
M!
Old   May 14, 2008, 09:02
bbb
hi, thankyou very much i will try this just now.
regards
Old   May 16, 2008, 04:47
bbb
hi, i tried changing the change pressure cycle to flexible. i never got the amg divergence message but on the other hand number of cells in which the turbulnce viscosity ratio was limited to 10e5 kept increasing and the solution never converged with silly forces.
any help?
regards
Old   May 16, 2008, 16:04
Meghnath
hi
you can try following
1 Give temperature dependent laminar viscosity because if you are analysing gases, lam viscosity will increase with temperature, which will reduce viscosity ratio
2 Patch viscosity ratio < 1e5 in complete domain and run
Initially, number of cells with vis ratio limited to 1e5 will increase but later it will strat desreasing
M!
Old   May 31, 2008, 10:07
bbb
hi, thankyou for the reply. can you please tell me where to do the changes in fluent ( i could not find ).
bbb
Old   June 10, 2008, 08:49
Rakesh Jha
Controls-limits
turbulent viscosity limited to viscosity ratio of Hua FLUENT 7 September 27, 2019 07:42
turbulent viscosity limited to viscosity ratio... frank FLUENT 19 December 15, 2015 23:54
"turbulent viscosity limited to viscosity ratio" olivier FLUENT 11 October 10, 2015 06:49
turbulent viscosity limited to viscosity ratio Elizabeth FLUENT 13 December 16, 2014 09:57
Turbulent viscosity Limited to viscosity ratio Adrian FLUENT 12 September 21, 2011 05:22
