Porous Formulation in Aerodynamic computation
Old   May 12, 2008, 05:13
Default Porous Formulation in Aerodynamic computation
F.B.
Hi all,
I'm doing the computation of the aerodynamics around an aeroplane, I use the segragated solver and I have to choose the porous formulation, physical or superficial, but in my simulation there is no porous zone, so why do Fluent ask me this option? Which one could be the better choice?
Thanks in advance
F.B.
Old   May 13, 2008, 18:40
Default Re: Porous Formulation in Aerodynamic computation
red lemon
porous formulation is only used if you have porous media. If no fluid regions are defined as porous then it doesn't matter which one it is set to and you can ignore.
drag coefficient computation on a porous jump??? Fabrice FLUENT 4 June 5, 2017 06:30
VOF formulation mvee FLUENT 3 March 12, 2007 07:35
Ale formulation Eduardo Guennam Main CFD Forum 1 March 1, 2006 02:32
physical velocity formulation and porous media KLG FLUENT 2 June 10, 2003 11:14
porous body formulation K. Natesan Siemens 0 November 22, 2002 04:29
