Modeling of furnace in Gambit
Old   May 9, 2008, 21:08
Default Modeling of furnace in Gambit
Abba H
Hey can somebody guide me
I'm trying to modell a coal furnace (power plant) in Gambit but Im having problem with the meshing. The Gambit at some point will stop and said no memory. Some one suggested that I should modell the furnace into different zones then mesh each of the volume seperately, but Im having difficulty in connecing the volumes. After I have modelled the furnace and mesh each volume seperately I cannot export it to fluent. It gives me error message that cannot export some faces and the whole volume. Pls can somebody give me an idea or guide into how I should go about this?
Old   May 11, 2008, 09:33
Default Re: Modeling of furnace in Gambit
Phil
Hey Abba,
The best approach is to firstly create the whole model as one volume. Then split the volume into its smaller pieces using the split volume function. You can split a volume using faces and volumes, and you can also split the faces and edges up to facilitate meshing.
After this you can create the mesh, and using the cooper mesh which extrudes the face mesh through a volume is a good bet. For best results link the 2 identical face meshes that you wish to extrude through using the link face meshes option - edges can also be linked which is useful.
Hope this helps
Old   May 11, 2008, 09:47
Default Re: Modeling of furnace in Gambit *NM*
Ahmad
Old   May 24, 2008, 20:35
Abba
Hi Phil
Thanks for the information. I have modelled the furnace, but Im still having problem creating the mesh, I have tried to mesh, but it gives me error message that some areas are too small to be mesh? The furnace Im modelling is about 500MWe coal fired boiler, it got 12 burners and 9 overfire air ports. How do u think I should go over this?
Old   April 13, 2010, 13:08
Default which model should i use for furnace?
Uday
patiludayv is on a distinguished road
Hi I faced one problem related to application of models used in fluent.
Which model should I use for modeling of furnace which having working temperature (inside temperature) of 700 degrees? Should I use Discrete Ordinate (DO) model?
How to decide which model is used to which temperature range?
please reply?
patiludayv is offline   Reply With Quote
Old   December 5, 2011, 15:28
Chris Mackidd
chris.mackidd is on a distinguished road
hey Abba
do you have any ready file for combustion in a furnace?
chris.mackidd is offline   Reply With Quote
Old   December 6, 2011, 10:04
deepak
student00 is on a distinguished road
Hi Abba
small areas are out of bound for mesh size we give to it for this......try stuctured or unstructured mesh...i think one of these will give you the answer.........
student00 is offline   Reply With Quote
Old   December 6, 2011, 12:59
Default mesh gambit Fortran
wissou22 is on a distinguished road
I’m trying to read a mesh generated from gambit and use it in FORTRAN, I know that I must read mesh file from gambit it fluent then export fluent case file to tecplot. But I couldn’t read this file in FORTRAN, is there a subroutine available for reading the tecplot file in FORTRAN.
Thanks you
wissou22 is offline   Reply With Quote
GAMBIT Modeling Problem Jahanzeb FLUENT 0 April 18, 2006 13:46
Gambit modeling troubleshooting Ng FLUENT 1 March 18, 2005 05:33
Parametric Modeling with GAMBIT David Shkval FLUENT 4 March 7, 2002 08:50
Modeling in Gambit Karon Young FLUENT 0 February 7, 2000 06:37
Electric arc furnace modeling.. Divyang Shah Main CFD Forum 11 June 22, 1999 14:29
