UDF for oscillating airfoil
Old   May 3, 2008, 08:50
Default UDF for oscillating airfoil
Wissam
I need an urgent help, i need a udf to be able to make my airfoil oscillate. am using fluent.
Old   May 6, 2008, 11:32
Default Re: UDF for oscillating airfoil
Amr
Why not have a look on the Fluent's UDF archive? Check the 6DOF UDF. You can take your problem further from there.
Good Luck, Amr
Old   May 6, 2008, 16:18
Wissam
Thx a lot Amr, I'll check the UDF archive..
Wissam
Old   May 11, 2008, 05:07
kardo
1) I have two zones in my grid.first zone near the wing is structure and the other is unstructure. if I use moving grid and udf, can i oscillate the structure zone during remeshing unstructure zone and stucture is fixed.
2)I defined a geometry that i splited the mesh of it into 2parts(structure & unstruc.). the near zone to wing is structure and the other one is unstructure.Between two zones, i defined interfaces.in fluent after defining B.C.,interfaces,...,check geometry i doesn't have any problem, but after intializing to start solution, Fluent shows me Warning and when i check the mesh, it fails and i'll have handedness problem(right-handedness & left-handedness)
Velocity of 3.5 for oscillating airfoil - logical? quarkz Main CFD Forum 0 April 13, 2006 01:12
oscillating airfoil test case Akbar FLUENT 0 July 15, 2005 07:49
BC for oscillating airfoil ganesh Main CFD Forum 4 July 7, 2005 13:29
Oscillating airfoil problem ganesh Main CFD Forum 2 June 27, 2005 14:57
Oscillating airfoil ganesh Main CFD Forum 0 June 23, 2005 14:20
