Divergence detected when using parallel solver
Old   May 2, 2008, 09:07
Default Divergence detected when using parallel solver
Phil
Hi all,
I'm having a problem when using the parallel solver where the solution stops and it says divergence detected.
The issue is that when running the EXACT same set of iterations on the serial solver, no divergence occurs and the solution converges very well. Also when divergence is detected, the residuals indicate that the solution is converging normally. For the parallel computation I'm using 4 processors.
Does anyone have any ideas? Any help is very much appreciated.
Thanks Phil
Old   May 2, 2008, 10:55
Default Re: Divergence detected when using parallel solver
cfd_newbie
Try to run the solver for two iteration (time steps) on the serial solver, save the case and data file. Then restart the solver in parallel mode read the previously saved case and data file ... and run your solution.
If this was helpful let me know.
Old   May 2, 2008, 12:00
Phil
Thanks for replying mate but I'm solving it steady state. Strangely its when I put the relaxation factors down that it diverges.
Any ideas?
Old   May 9, 2008, 09:17
Aris Nikolopoulos
Any UDFs? Particles involved? What release are you using?
divergence detected in AMG solver azalina FLUENT 5 September 20, 2012 19:57
divergence detected in AMG solver. Babu FLUENT 3 March 4, 2005 04:08
divergence detected in AMG solver: Shekhar Jain FLUENT 1 September 18, 2003 10:31
HELP! divergence detected in AMG solver ann FLUENT 3 January 4, 2003 02:27
Divergence detected in AMG solver? varghese FLUENT 5 May 27, 2002 08:50
