How to change domain extents in fluent
Old   April 25, 2008, 13:59
Default How to change domain extents in fluent
kbs
I am drawing pipe as 3D cylinder in gambit and export the mesh into fluent. When I check the grid fluent show the following dimensions:
Domain Extents:
x-coordinate: min (m) = -3.061516e-017, max (m) = 2.500000e+001
y-coordinate: min (m) = -4.925000e-002, max (m) = 4.925000e-002
z-coordinate: min (m) = -2.789934e-017, max (m) = 4.925000e-002
where x is the dimension towards the cylinder length and the (y & z) coordinates towards the radial direction. The last to coordinates appeared in fluent as (-R & +R) I want these coordinates start from 0 to full diameter of cylinder not as shown above how can I do this please help ?
Thanks a lot KBS
Old   April 25, 2008, 20:22
Default Re: How to change domain extents in fluent
AAA
Hi
go to Grid-->translate
Regards
AAA
Old   April 26, 2008, 09:18
kbs
hey AAA the method you suggest solve part of the problem along the y-direction but the probelm still exist with the z-coordinates its start from 0 to radius of cylinder. I set the cylinder as symmetric along the y-axis and used mirror option to complete the cylinder along the z-direction but the dimension of it not change what can I do then?
Thanks a lot
Old   April 26, 2008, 17:07
AAA
Hi
First of all, I think you have a scale problem. From your first message, your x- range goes to e-17 m. Please check the dimensions.
If you are using symmetry, your domain will be what you have drawn in Gambit. The extra half you will see with the mirror option at the postprocessing stage is not part of the domain considered in the scale option.
If the flow is mainly along the length of the cylinder, consider modeling 1/4th of the cylinder with two symmetry faces.
Regards
AAA
Old   April 26, 2008, 17:32
Default correction!
AAA
Hi again
I apologize for not paying attention to the "e-17 m" in the past message, which equals to zero. Sorry for that.
Regards
AAA
Domain extents Arianna FLUENT 0 May 14, 2007 07:20
can we change the dimensions in fluent Rashmi FLUENT 3 April 3, 2006 04:35
Change Fluent.cas and .dat possible? Pat FLUENT 0 February 10, 2005 08:26
moving grid with domain size change Hu Main CFD Forum 5 May 13, 2004 22:14
Domain size change. Paul FLUENT 2 October 11, 2003 17:34
