Having problem in creating a volume mech in GAMBIT
Old   April 25, 2008, 05:20
Default Having problem in creating a volume mech in GAMBIT
Jake
I am trying to mesh a volume. The volume is basically a 6 sided brick, with one of face that I put face mesh are made up of several faces while the opposite face is made up with only one face.
For that, I am trying to use a Cooper scheme to imprint similar face mesh to the other side, and it seems that portion is successful.
However, as with other 4 faces that covers the rest of the volume are giving me the problem. While 3 of 4 are meshed with right orientation to their corresponding faces, one on the back is giving me a face mesh all the way twisted.
You may imagine it as one twisting a piece of paper while holding both ends. As the result, the middle section of the meshed face is actually protruding out of the constructed face.
I tried to only mesh the problematic face, and got the same problem.
Any thought how to fix this problem?
Old   April 25, 2008, 06:01
Default Re: Having problem in creating a volume mech in GA
mAx
if you delete your mesh and then switch the visibilty on "shaded", is this twisted problem still visble? if yes, then it isn't a mesh problem, but a construction problem.
Inclusive option (for creating volume) in CFX-Post KK CFX 0 February 4, 2008 20:25
Gambit Meshing volume problem haamdy FLUENT 11 August 10, 2007 09:39
creating volume from a surface file for CFD Amir Main CFD Forum 0 December 24, 2002 03:08
creating volume by stitching faces Prabhu.B FLUENT 3 June 27, 2002 20:33
Creating vents(faces) in a cubical volume Julie FLUENT 6 June 6, 2002 12:27
