valve motion 3D
Old   April 19, 2008, 08:20
Default valve motion 3D
j
I'm using fluent to simulate the movement of valve and piston in an ic-engine. and gambit to make the mesh.
my problem is i have to mesh the inlet port but not the valve that is inside the inlet port. because now the volume mesh i put on the inlet port goes true my valve.
can anybody help me? thanx
Old   April 19, 2008, 11:02
Default Re: valve motion 3D
vk
You can subtract the valve volume in Gambit. If there is no volume inside the valve, you won't get the mesh inside.
Old   April 24, 2008, 08:02
j
thank you for the help
gap between valve stem valve kantharao Siemens 0 September 2, 2008 08:19
valve motion skarp CFX 2 April 29, 2008 19:51
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 13:30
How can i simulate a valve motion ???????? popi CFX 6 September 19, 2006 11:54
I.C. Valve motion Mike FLUENT 2 March 8, 2006 14:32
