mean velocity change from inlet to outlet
Old   April 19, 2008, 04:59
Default mean velocity change from inlet to outlet
ro
When I simulate the flow in a channel and after solution is converged .When I calculate the mean velocity by surface integrals the mean velocity is found 1-differ from the inputed value at the velocity inlet B.C and 2-differ from the mean velocity at the outlet of the channel which have pressure outlet B.C In fact as I know must be the mean velocity is equal from inelt to outlet .So why this happened ?please how know the answer to help me
Thanks alot
Old   April 19, 2008, 10:34
Default Re: mean velocity change from inlet to outlet
k.baker
if you solve with non-fully developed flow it usually differ but if your case was fully developed it must become the same.
Old   April 19, 2008, 14:37
ro
My case is developing flow.But why it differ since according to the continouty equation must be the mean velocity inlet is the same at outlet to conserve the momentum .But in my results it differ I need the physical meaning of this change
Thank you for your replay and answer
velocity inlet and pressure outlet Ebrahim FLUENT 5 January 15, 2015 18:14
IDW velocity interpolation near inlet or outlet Marcin Main CFD Forum 0 April 23, 2007 20:21
Velocity on inlet and outlet greg FLUENT 2 March 7, 2006 08:16
Define mass fraction for -ve velocity inlet/outlet KKLAU FLUENT 1 June 14, 2004 15:23
Change outlet to inlet Christian FLUENT 0 February 13, 2003 04:44
