Falling sphere
Old   April 16, 2008, 21:09
Default Falling sphere
Graham
I'm a newbie to Fluent. I have a problem and I'm hoping somebody can give me some tips or point me to some relevant examples to get me started.
Very simply, I want to begin by modeling a glass sphere falling in a water tank (no flow) due to gravity, both away from the wall or near to a wall.
I can find how to model droplets or bubbles, or even dispersed particles, generated by nozzles and so on, but I do not understand how to place a single solid sphere at a position in the tank (x,y,z) at time t=0 and then model how the fluid interacts as it falls due to gravity.
Hopefully someone can show me a similar project.
This is not for a homework project.
Old   April 17, 2008, 02:15
Default Re: Falling sphere
CDE
you can use the discrete phase model (DPM). Just set up an injection at a point and display the particle trajectory
Old   April 17, 2008, 03:05
Graham
Right, but doesn't that assume the spheres are point-like and do not perturb the flow?
I want a fulling interacting solid sphere that is falling due to gravity and displacing the fluid. There is no flow, it's falling in an isolated tank, so I'm not sure how the particle tracking would work.
My spheres are not necessarily point-like.
Ultimately, I want to be able to model the passage of the fluid around the sphere, rather than the actual path followed by the sphere itself (although that would be a nice by-product).
Old   April 17, 2008, 03:36
CDE
ok, thats quite a different problem. You are correct that the DPM assumes the volume fraction is negligible and will not perturb the fluid. Have a look at the VOF model. Maybe you can tweak the settings of the second fluid and surface tension to imitate a solid particle. This is just a suggestion and I'm not sure it will work!
Old   April 17, 2008, 04:46
Graham
Yeah I was thinking of that, but it seems like something of a fudge.
I would have though a sinking sphere would be a standard kind of problem, with a well-worn solution.
I was thinking of using dynamic meshing, but I think that requires prior knowledge of the behavior of the sphere, which I might not have (for instance if it gets close to a wall).
Old   April 17, 2008, 08:22
Giles
The newer versions of Fluent include a 6DOF solver, which you can set up with dynamic meshing so that you start with an initial mesh, and it will compute the flow and any extra forces you may wish to add such as gravity, and time step the mesh with dynamic meshing to model the spheres movement with time. Fluent use an example of a bomb falling from a bomb bay as an example of this is their tutorials, I'd recommend trying to find that as its very similar.
Old   April 17, 2008, 19:26
Graham
Thanks.
Do you have a link for that particular example? I don't appear to have it with my installation (Fluent 6.3).
It sounds ideal. I think the 6DOF is the way forward for this problem.
Old   April 23, 2008, 20:13
Giles
Sadly I've only got a a paper copy, its part of Fluent's training program for dynamic meshing. Possibly contact fluent and they may be able to supply it to you electronically.
Old   April 23, 2008, 20:15
Graham
What's the name of the article? I should have access to it, but I can't see a link on their site at the moment.
Old   April 25, 2008, 13:34
Giles
The one day course for dynamic meshing notes: Lecture 6: Coupled flow via the 6 DOF Solver of 1DOF UDF
and
Tutorial 5: Coupled Flow using 6DOF (store separation from a 3D delta wing)
Old   April 25, 2008, 14:02
  #11
Graham
Thanks. I will look at this. I also discovered the falling box example that was enough to get me going (for now). Thanks!
CFD for falling film evaporator Binglu Ruan FLUENT 11 March 11, 2020 13:51
droplet falling - VOF bohis FLUENT 1 July 10, 2013 05:28
falling drop ozgur FLUENT 6 October 23, 2012 04:56
falling of ball in water nabeel mohsin FLUENT 2 November 26, 2004 06:50
sphere falling in an infinite liquid medium sreenivas CFX 0 February 13, 2004 08:59
