UDF growing radius
Old   April 10, 2008, 08:45
Default UDF growing radius
Greg
I try to simulate the wave of a blast.
So as to do that, I try to make moving a semicircle wall imputing the blast equation.
How can I imput this displacment when it is actually an enlargement of the radius of this semicircle?
I don't know how I can imput a rate of change of the radius.
If you have another idea, each point of this semicircle as to move with the same speed but in a different direction.( along its radius)
Thank you very much for your help.
Greg
Old   April 11, 2008, 11:19
Default Re: UDF growing radius
Greg
Like I have no answetr I will try to simplify my question.
By using Define_Geom I want to set a movement depending of time.
My equation would look like something like this:
(position[0]-a)^2+(postion[1]-b)^2=((dtime-t0)*e(dtime-t0))^2 where a b are coordinate of the center of the circle and the second member of the equation the varying radius.
Any help or comment would help me.
Greg
Hydraulic diameter vs radius Christian Main CFD Forum 8 August 5, 2009 19:10
Av. static pressure (above/below specified radius) KM CFX 0 December 25, 2007 20:31
spectral radius R wxm Main CFD Forum 0 August 6, 2006 03:33
The ever growing .def file! James Date CFX 2 May 23, 2005 23:30
radius of each cell centroid Bikash FLUENT 0 March 3, 2005 17:33
