Custom Field Function
Old   April 8, 2008, 14:23
Default Custom Field Function
Corentin
Is there any possibility to call a custom define function in the code of a UDF, instead of computing it in the Fluent window?
For instance, I would like to compute a surface integral, over a specific surface. I know how to make it in the Fluent window, but what if I want to compute it automatically after each time step for instance, and save the result in some file?
There must be a way to make it, huh?
Thanks!
Old   April 8, 2008, 21:54
Default Re: Custom Field Function
Aidan
this can be easily done by setting up a surface monitor,which is under the solve menu, and setting it to write the data to a file after each time step.
Old   April 9, 2008, 03:25
Corentin
Ok, thanks, I'll try this!
UDF vs Custom field function andrew FLUENT 5 June 24, 2011 11:53
Custom Field function...>>>Please HELP..! sushii FLUENT 2 October 11, 2007 02:04
custom field function Meenu FLUENT 1 November 30, 2006 20:23
custom field function Ana Raquel FLUENT 1 November 30, 2006 16:25
Custom field function Rashad FLUENT 0 October 10, 2006 07:56
