RSM with Eulerian, tips for convergence?
Old   April 7, 2008, 14:19
Default RSM with Eulerian, tips for convergence?
Paul
I'm running a RSM unsteady simulation with Eulerian multiphase enabled with two phases (a gas and a particle stream). I'm having trouble getting it to converge however. I'll get a few seconds into the simulation and then I start getting errors followed by the inevitable "floating point exception".
Anyone have any tips on how to get it to converge?
Old   April 9, 2008, 08:19
Default Re: RSM with Eulerian, tips for convergence?
fluent
http://venus.imp.mx/hilario/SuperCom...ml/node385.htm
Old   April 9, 2008, 14:01
Paul
The RSM isn't the problem. I can solve the model using only RSM, its when the Eulerian is enabled that I'm getting problems.
Old   April 9, 2008, 14:25
Paul
Okay let me explain in a little more detail what I've done:
I am attempting to run a simulation of a cyclone using the RSM-unsteady-eulerian multiphase model.
Previously the model has converged using RSM-Unsteady with no multiphase model.
I ran with the multiphase enabled (2 phases), and I kept getting floating point errors once I got to a certain point (around 4s). I checked fluent's manual and they suggested running the simulation without volume fraction selected in the solution menu until convergence.
I ran this model until the solution conditions were basically steady state (no changes in results for varying time steps). I then reenabled the volume fractions, but it soon bombed out due to the "turbulent excursions".
I then tried turing the turbulence equations off in the solution, and have been running it since. I'm around 48s, and based on the results I have it is nowhere near convergence. I'm running with a time step size of .001s which converges in about four iterations, however when I try to increase the size the residuals diverge wildly.
Anyone have any suggestions about what I can do (preferably with all the solution equations (turbulence/volume fraction) enabled)?
Singularity in two fluid model (Eulerian-Eulerian) Zak Main CFD Forum 4 February 28, 2010 18:54
Eulerian-Eulerian for 1% dispersed phase Kushagra CFX 1 May 23, 2008 05:03
Convergence tips John CFX 3 August 28, 2005 02:15
Convergence of Eulerian-Lagrangian part. tracking Sven FLUENT 4 July 30, 2004 06:34
enabling UDS in Eulerian-eulerian multiphase model shao1 FLUENT 0 July 14, 2002 23:23
