Fluent in text mode
Old   April 7, 2008, 09:08
Default Fluent in text mode
Aris
Hi!
I'm running fluent 6.3.26 in unix (text mode -gu). It all works fine but i have the following problem. When i iterate (for example it 50) fluent calculates only one iteration! I switched off any residual/monitor plot.
Any idea?
Moreover i used text mode in order to decreade the RAM needed. Is there any possibility that with text mode the necessary
RAM will be decreased?
What about speeding up the calculations?
Thanks in advance Aris
Old   April 15, 2008, 08:13
Default Re: Fluent in text mode
Aris
I found the problem. "It" iterates in the curent time step. The correct is dual-time-iteration! Still, does anybody knows if the necessary RAM will be decreased?
text shortcut commands for fluent senthil FLUENT 0 November 21, 2007 14:39
How to run the CFX-solver in text-mode? bcomz CFX 2 November 16, 2005 00:08
Changing colors in fluent text menu venugopal FLUENT 0 July 16, 2004 14:20
Fluent Command Text to display several Partic Laurence Wallian FLUENT 2 September 16, 2003 09:38
create executable and batch file in text mode Johan Siemens 2 July 23, 2000 13:02
