Help Needed
Old   April 3, 2008, 17:07
Default Help Needed
Saravanan
I am New to Fluent. I want to whether this problem can be done in FLUENT or not. I will try to explain the problem. I am simulating a molding process. After the molding is done, a coolant is passed thru cooling channels over the the mold dies. I want to calculate the heat flux all over the model. And also I want to the temperature distribution inside the finished mold.I think this one is a conjugate heat transfer problem, it involves conduction thru solid.
Thanks
Help Needed S FLUENT 5 April 22, 2008 13:58
Help Needed Saravanan FLUENT 1 April 12, 2008 21:14
help needed vivek FLUENT 1 November 15, 2006 05:28
New to UDF Help really needed Amr FLUENT 4 June 9, 2006 17:44
Help needed with UDF sam FLUENT 5 October 26, 2005 03:48
