How to simulate a static pressure sensor?
Old   April 3, 2008, 08:38
Default How to simulate a static pressure sensor?
axel cole
Hy guys,
i would like to simulate a static pressure sensor on a duct. I've put a small diameter pipe on the duct surface. I'd like to know which boundary condition i must impose on the top of the small diameter pipe. Do you think that a WALL boundary condition could be right?
Thanks in advance
Old   April 3, 2008, 11:11
Default Re: How to simulate a static pressure sensor?
linfan
may be you can set it as a pressure outlet!
Old   April 3, 2008, 11:13
linfan
at the mean time,set the target mass flow to zero.
Old   April 4, 2008, 10:20
Neil
Define the sensor region of the duct geometry as a wall then apply a surface monitor to plot/write static pressure
How to simulate a static pressure sensor ? axel cole Fidelity CFD 1 August 22, 2008 21:01
How to simulate a static pressure sensor? axel cole Siemens 1 April 16, 2008 18:49
How to simulate a static pressure sensor ? axel cole Phoenics 0 April 3, 2008 08:40
How to simulate a static pressure sensor ? axel cole CFX 0 April 3, 2008 08:39
How to simulate a static pressure sensor ? axel cole Main CFD Forum 0 April 3, 2008 08:38
