ERROR in user-defined database materials
Old   March 31, 2008, 07:26
Default ERROR in user-defined database materials
Julien Lepaul
I'm trying to run a user-defined database but Fluent says : Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: eau-usee
Here is the user-defined database :
(eau-usee fluid (density (constant . 999.7)) (specific-heat (constant . 4193)) (thermal-conductivity (constant . 0.528)) (viscosity (constant . 0.00131)) (molecular-weight (constant . 18.1)) )
(fluide-caloporteur fluid (density (constant . 998.2)) (specific-heat (constant . 4182)) (thermal-conductivity (constant . 0.6)) (viscosity (constant . 0.001003)) (molecular-weight (constant . 18.1)) )
(inox solid (density (constant . 7850)) (specific-heat (constant . 486)) (thermal-conductivity (constant . 16)) )
What is the problem ? Thanks
Julien
Old   April 16, 2008, 00:10
Default Re: ERROR in user-defined database materials
Gustavo
Hi!! I had that problem but I discovered that you need to set another () for all that code you wrote, e.g.
(Aluminio solid
(chemical-formula . Al)
(density (constant . 3000))
(specific-heat (constant . 871))
(thermal-conductivity (constant . 202.4))
(formation-entropy (constant . 164448.08))
Old   April 16, 2008, 04:43
Julien Lepaul
Thanks! Now it works
Old   April 16, 2008, 10:13
Julien Lepaul
Hi! I want to know what is the "text command" to copy materials from user-defined database. "define materials copy" don't works. Thanks,
Julien
User-Defined Material Database Domenic FLUENT 1 June 1, 2015 10:34
How to use User defined database to add material sangeeta FLUENT 1 February 25, 2009 14:02
User defined function causes error !!!! CFDLife CFX 2 February 23, 2009 12:29
User- defined properties of materials Vidya Raja FLUENT 0 March 1, 2006 15:28
Adding New Materials To Database utku FLUENT 2 April 11, 2005 13:06
