external gear pump with fluent
Old   March 29, 2008, 06:15
Default external gear pump with fluent
Pietro Ghillani
Hi! I'm trying to simulate two meshing gears in a hydraulic pump with Fluent. I have written the UDF for the movement of the gears and the remeshing for each time step. This seems to work fine. The problem is that when I make the first analysis the results show no movement of the oil that should be drag by the gears! I have tried imposing different boundary conditions declaring the rotating speed of the walls representing the gears but nothing happens. The only way to obtain something is to define the rotating speed of the oil and to set as stationary the gears but this is "correct" just for one of the gears and not for the other. Any suggestion? Thank you in advance.
Old   March 16, 2009, 14:37
Mustafa Ayad
interawe is on a distinguished road
Hi
I working as same as you about gear pump, I wish we can cooperate and exchange information, my problem that velocity vector direct from outlet to inlet. I want to know more about you and your work. Give me your email to send one another files PDF etc…….
Regards.
Mustafa Ayad
interawe is offline   Reply With Quote
Old   March 16, 2009, 19:19
Default gear pump
Artem
Doctor is on a distinguished road
Hi, Mustafa! I'm trying to simulate a gear pump with Fluent. I've made some progress in this kind of simulations but I have problems too. Maybe we could help each other with some questions? if you are interested in such cooperation write me on my email adress :
kaktus335@mail.ru
PS I'll be thankful for any information about simulating of gear pumps (gerotors) in fluent!
Doctor is offline   Reply With Quote
Old   March 18, 2009, 09:48
abdi
nabil is on a distinguished road
Hi friends, i am verry interrested what you are doing, if possible explain me steps how to do, or send me *.dbs file if possible. " i am begineer in fluent"
nabil is offline   Reply With Quote
Gear Pump Elian81 CFX 5 August 1, 2012 19:50
gear Pump elia81 CFX 5 June 2, 2010 19:36
3D External Gear Pump Mustafa Ayad FLUENT 1 January 26, 2009 10:55
C.G of Gear Pump Mustafa Ayad FLUENT 0 January 23, 2009 15:53
