GAMBIT problem with 3D Boundary Layer when meshing
Old   March 25, 2008, 09:17
Default GAMBIT problem with 3D Boundary Layer when meshing
Anthony Haroutunian
Hi all,
i got an error when meshing the domain volume. At the trailing edges of a boat keel with the ballast bulb the surface boundary layer on the foil and bulb surface don't go around the "trailing edge" edge and when meshing, GAMBIT gives an error : "Currently, 3D boundary layers are limited to flat face groups with the same boundary layer on all faces. A discontinuity has been found where one face has a boundary layer and the adjacent one does not. The problems occur in volume v_volume.6 along the following edges : v_edge.136, v_edge.148 and v_edge.133"
I tried to add the trailing edge edge in the Boundary Layer but it doesn't help
Any Idea?
Thanks
Anthony
Old   March 26, 2008, 00:08
Default Re: GAMBIT problem with 3D Boundary Layer when mes
Aidan
That error occurs when you don't have all the faces selected correctly. Also, it occurs when gambit can't find a logical start-finish point for the 3D boundary layer. Are you trying to wrap the boundary layer around the trailing edge?
Old   March 26, 2008, 03:02
Anthony Haroutunian
Yes I'd like to wrap the BL around the trailing edge! do you know how to do that ? even with the "wedge corner shape" option in the BL menu, it does not work. Thanks
GAMBIT meshing problem for boundary layer Falah FLUENT 2 November 30, 2020 15:16
gambit boundary layer meshing Rick FLUENT 7 May 5, 2016 14:29
Boundary layer meshing rav_aero FLUENT 1 September 21, 2007 10:51
How to do boundary layer meshing in a 3D diffuser Durgendra Main CFD Forum 1 June 26, 2006 09:18
boundary layer meshing santosh FLUENT 6 November 1, 2001 18:54
