Oxy Fuel combustion
Old   March 25, 2008, 01:48
Default Oxy Fuel combustion
Ant
Hi Guys,
I am modeling different types of industrial combustion cases where we use pure oxygen as oxidant.
We get decent results with equilibrium assumption using PDF model. However for more complex situations where we have two oxidants or two fuels (second fuel being of low calorific value and slow to combust) and for flameless combustion equilibrium assumption does not hold good.
I am trying some custom kinetics using some dissociation reactions which should predict proper temperature using EDM +FRC. I am having a hard time getting this case to converge. After running for a long time I see that the mixture fails to ignite and very often I temperature exceeds 5000 K away from the region of the flame.
Any experience with oxy-fuel combustion and help with convergence issues of FRC model would be highly appreciated.
Regards, Ant
Old   March 31, 2008, 07:43
Default Re: Oxy Fuel combustion
Djamel
i work with fluent and specilly with pdf model in the combustion . you can send me a message think you
Old   April 4, 2018, 03:53
Sujeet Yadav
sujeety90 is on a distinguished road
I am trying to do oxy-fuel combustion simulation in fluent using non-premixed approach. I have replaced N2 by CO2 in the boundary of oxidizer. I wanted to know what other changes are required during oxy-fuel fluent input in comparison to air combustion fluent input.
sujeety90 is offline   Reply With Quote
Solid Fuel Combustion Peter Moss FLUENT 11 July 15, 2022 00:06
Diesel fuel combustion Marek CFX 1 November 30, 2008 14:39
Combustion with blended fuel torvic OpenFOAM Running, Solving & CFD 3 April 14, 2008 17:22
liquid fuel combustion camby CFX 0 April 26, 2007 22:32
combustion of solid fuel. talha FLUENT 0 March 21, 2006 13:12
