Simulation of object in rotation
Old   March 21, 2008, 12:38
Default Simulation of object in rotation
Dothan
Hi, I'm working with Fluent for simulate the influence of an object that rotate in air. I've created a volume and I've subtracted my object, so I obtain the walls that rappresent my object. Now, How can I use the boundary condition for simulate the rotation? -I can't set only the wall velocity because, like manual say, this method trasmit only tangential forces and isn't suitable for movement that is normal to wall. -If I use Single Reference Frame rotation, fluid->moving reference frame in rotation with the angular velocity opposite than the object angular velocity, and I set the object to be stationary in the absolute frame, I think this method don't model the real phenomenon. ( for example: SRF introduce a radial gradient of pressure).
So, How can I model this problem in a suitable manner?
tnx
Old   March 22, 2008, 18:57
Default Re: Simulation of object in rotation
Hirdesh
As object is rotating in air i.e. outer domain should remain stationary. Use MRF instead of SRF. make two zones. one rotaiong zone that include rotating object. Another one is stationay outer zone. I hope this will help you.
Hirdesh
Old   March 23, 2008, 15:45
Stefano
Hi, I perform a simulation of a helicopter's blade and I have used the stationary condition for the wall and the MRF for the fluid too.So I have got a good results. I hope to be helpful. Bye
Old   March 23, 2008, 15:46
Stefano
Old   March 25, 2008, 04:25
Dothan
Hi, many thanks for yours replies. If I have undestand,I can applicate the same method showed in the Tutorial #9 "Using Multiple Rotating Reference Frames", Fluent documentation 6.3. So I must create a fluid volume which contains the fluid near my "wall" object ( if I incorporate some fluid far from my object I think this isn't correct, isn't?). I must associate this volume at the first reference frame, with angular velocity equal and opposite than object velocity. The second rotating reference frame is referred to the ambient volume, and is stationary. A question: The fluid in the first rotating reference frame near my object I impose that it is rotating, but in the real problem it isn't moving. Is this correct?
tnx Dothan
UDF to change Rotation Speed in a MRF simulation Mike FLUENT 3 September 27, 2011 07:46
How can i run a FSI simulation of a rotation wall romance CFX 0 November 27, 2007 08:35
Rotation Angle In MFR Simulation Ste_lakey CFX 2 November 8, 2005 06:22
rotor simulation having both rotation and translat kumar CFX 1 November 14, 2002 20:18
rotation flow field simulation wason FLUENT 1 May 26, 2000 14:10
