How to display three isothermal line in FLUENT?
Old   March 21, 2008, 00:42
Default How to display three isothermal line in FLUENT?
marqueen
Dear all,
In temperature result from my FLUENT calculation, I want to display three isothermal line: 700K,800K,900K. Can I realize that by Fluent? Thanks.
Old   March 21, 2008, 06:48
Default Re: How to display three isothermal line in FLUENT
Vinod Dhiman
Yes. Use overlays available in Scene.
Old   March 21, 2008, 13:28
red lemon
Surface>Iso-Surface>Constant Temperature then display all surfaces at once in Grid>Display>Contours
Old   March 21, 2008, 14:41
marqueen
Thanks Dhiman and Lemon,I want to put the temperature number on the pic. I still dont know how to do that. Thanks
Old   March 25, 2008, 05:28
Gernot
If it is what i mean then its easy :
Open the display contour panel :
disable : filled and autorange
set levels to 3
set min to 700 and max to 900
think that should work
Old   March 28, 2008, 08:09
linfan
You can use the annotate function provided by fluent.
how to display the stream line ice FLUENT 1 February 21, 2007 09:54
Path line display Jass FLUENT 0 February 15, 2007 03:02
rotating display of fluent Rose FLUENT 2 September 26, 2003 06:36
why Fluent can not display the grid? cwflying FLUENT 3 May 12, 2002 22:14
Non-Isothermal Flows Juliana Main CFD Forum 3 November 29, 2001 10:45
