Porous Media Inertial and Resistance
Old   March 20, 2008, 04:58
Default Porous Media Inertial and Resistance
giogio
hi, What is the difference between inertial coefficient and resistance coefficient il inputs for Porous Media ? Thanks
Old   March 21, 2008, 13:30
Default Re: Porous Media Inertial and Resistance
red lemon
one is inertial resistance and other is viscous component of resistance
Old   April 2, 2008, 03:29
DEV
read Ergun equation for pressure drop per unit length to understand more
Old   June 21, 2011, 19:09
zohreh
zhhjll is on a distinguished road
I want to model a micro filter, This filter (membrane) is rectangular (10×5 cm) with the thickness 12e-5. so,I calculate this parameters from Ergun equation which D=1e-6, because of the Micro filter type. is this assumption true??
i think this is very thin filter so there in not flow through in the membrane, in this situation is inertial coefficieant higher in Y direction? or not?when i set y-direction inertial coefficient higher than x-direction got better answer! is this resonable?
I am looking forward to hearing from you.
Sincerely yours
zhhjll is offline   Reply With Quote
viscous resistance coefficients in Porous media choyong FLUENT 9 December 15, 2014 21:01
porous media resistance coefficients Thiyagarajan FLUENT 5 October 27, 2011 07:24
Gas generation with resistance in porous media billow Phoenics 5 June 21, 2011 19:11
resistance to droplets in porous media zhzhguo FLUENT 3 November 22, 2004 09:37
Flow resistance of porous media Desheng Kong Main CFD Forum 3 December 19, 2000 12:07
