boussinesq approximation
Old   March 20, 2008, 02:21
Default boussinesq approximation
jamal
DEAR FRIEND, my project is on opposed bouyancy flow over a SQUARE cylinder .THE FLUID IS AIR . i am using boussinesq approximation in my problem.when i choose boussinesq approximation in the drop down list of material panel, a constant value of density is required. i wanted to know what constant value of density should i give in the material panel.should it be 1.225 OR CAN I GIVE ANY ARBITRARY VALUE. I WILLL BE EAGERLY WAITING FOR YOUR VALUABLE REPLY...
THANKS
Old   March 22, 2008, 19:11
Default Re: boussinesq approximation
Hirdesh
HI,
Boussinesq approximation needs constant value of density, of fluid under study.as your fluid is air. use density of air.
Old   March 25, 2008, 09:57
jamal
thank u very Hridesh for yr valuable information...
InterFoam with boussinesq approximation sinusmontis OpenFOAM Running, Solving & CFD 2 October 25, 2020 13:21
Boussinesq approximation Abdul Aziz Jaafar Main CFD Forum 19 May 3, 2019 12:00
Boussinesq approximation Joshua Siemens 0 July 9, 2008 12:13
Boussinesq approximation Volker Phoenics 0 September 5, 2003 16:48
Boussinesq approximation again Gabriel Main CFD Forum 3 May 11, 2000 10:24
