Boundary condition for supesonic nozzle simulation
Old   March 19, 2008, 16:55
Default Boundary condition for supesonic nozzle simulation
Abhinav Choudhari
Hi all, I am doing 3d simulation of convergence-divergence nozzle with supersonic flow. Mach no. around 2. I am using std K-e model. I would appreciate if someone can suggest me what would be the proper wall conditions for the nozzle. The average thickness of my nozzle is 0.1 inch. I went to couple of research paper, some have used adiabatic wall and some as constant temperature wall. Since this is supersonic flow simulation, I am not sure what to use as wall condition. I will really appreciate any suggestion on this. Thank you in advance. Abhinav
Old   March 19, 2008, 19:56
Default Re: Boundary condition for supesonic nozzle simula
Hirdesh
Both wall conditions are right. A adiabatic wall can be maintained at constant temp.
Old   March 19, 2008, 20:28
Abhinav Choudhari
Hi Hirdesh, Thank for replying so quick. What you say adiabatic wall will be good or convective wall with specific heat transfer coefficient will be the good option for me. As flow is supersonic and mtl of nozzle is steel with 0.1 inch thickness.
Once again thank you very much for reply. Abhinav
Old   March 19, 2008, 21:53
Hirdesh
Hi, I think solid wall can't be convective. So better to take adiabatic wall.
Hirdesh
Old   March 26, 2008, 04:31
Ramesh. K
What exactly do u need at the wall are u planning to study the flow properties or the heat transfer across the wall. if your interest is only flow you can have only no slip condition at the wall and leave the default options of wall boundary condition as it is or if u need to study the heat transfer coefficient then u need to bother about it as maintaining the wall at constant temp or adiabatic
it entirely depends on ur problem definiton
Old   March 28, 2008, 15:06
Abhinav Choudhari
My main aim to analyze flow and in particular shock waves ... So I wanted to keep boundary condition simple still realistic ... What you suggest I should use as Boundary condition, as boundary condition is important for realistic results. Thank you.
Old   September 26, 2009, 05:31
zaw
tunzaw
zaw is on a distinguished road
Dear Abhinav and all
I am also trying to simulate 3d CD nozzle flow. But I am very bad in grid generation. I use GAMBIT for grid generation. If you have any example of 3d CD nozzle grid generation and FLUENT simulation, help me please. I wonder if you make reply to me. my email is tunzawcn@gmail.com
zaw is offline   Reply With Quote
nozzle boundary condition Shuo Main CFD Forum 4 September 28, 2007 08:28
boundary condition at nozzle exit Akbar FLUENT 1 June 30, 2005 06:46
Boundary condition, UDF, Wave simulation hm FLUENT 0 August 2, 2004 22:45
boundary condition for fan simulation Mark Main CFD Forum 2 March 31, 2004 12:46
2D simulation as boundary condition for 3D problem Jan De smet FLUENT 1 October 11, 2002 03:02
