Running Fluent on an SGI Altix machine
Old   March 18, 2008, 21:52
Default Running Fluent on an SGI Altix machine
Jonathan Vogt
Hi there, I'm attempting to get (non-gui) fluent to run on a new SGI Altix machine but have gotten nowhere as yet. The job opens but then basically does nothing.
The fluent bit of the script:
fluent 3ddp -t 5 -paltix -cnf=hosts.${PBS_JOBID} \
-g -ssh < [journal-file] > [output-file]
I've also tried -mpi=hp (instead of '-paltix', but that produces the same result which is (from the result file, which is oddly copied back to the home directly immediately after starting the job):
[LINE] means new line - this website seems to ignore the enter/return button half the time!
/usr/local/fluent/6.3.26/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3ddp -t 5 -paltix -cnf=hosts.8763.mclaren -g -ssh [LINE]Warning: host "hosts.8763.mclaren" is not reachable by ssh; skipping checks on remote node [LINE]Loading "/usr/local/fluent/6.3.26/Fluent.Inc/fluent6.3.26/lib/fluent.dmp.114-64" [LINE]Done. [LINE]/usr/local/fluent/6.3.26/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3ddp -paltix -host -t5 -mpi=sgi -cnf=hosts.8763.mclaren -path/usr/local/fluent/6.3.26/Fluent.Inc -ssh -cx mclaren:2033:19965
Host spawning Node 0 on machine "mclaren" (unix). /usr/local/fluent/6.3.26/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3ddp -node -t5 -paltix -mpi=sgi -cnf=hosts.8763.mclaren -ssh -mport 172.16.1.221:172.16.1.221:20282:0
Any ideas as to what might be going on here would be greatly appreciated. Thanks very much.
Jonathan Vogt.
Old   March 19, 2008, 02:35
Default Re: Running Fluent on an SGI Altix machine
Jonathan Vogt
For posterity, I should let you (anyone who has the same problem) know that I managed to resolve the issue by changing the script file to the following:
fluent 3ddp -t 5 -paltix -g < [journal-file] > [output-file]
ie, I deleted, '-cnf=hosts.${PBS_JOBID}' and '-ssh'.
Running icepak on a linux machine Codemaster FLUENT 0 November 20, 2008 01:50
OF on Altix Itanium2 machine skabilan OpenFOAM Installation 0 December 14, 2007 05:04
Running paraFoam on remote machine makh OpenFOAM Running, Solving & CFD 3 December 4, 2006 05:12
Installation on IBM machine running AIX gellert OpenFOAM Installation 2 October 14, 2005 05:26
Running Fluent on Linux AMD machine David Reinbold FLUENT 5 September 21, 2001 18:08
