drag of cone
Old   March 17, 2008, 09:37
Default drag of cone
Ebrahim
I'm trying to calculate the drag of a cone in fluent. My model is 2D, using symmetry.
I defined the wall of the cone as a seperate wall to calculate forces on the wall.
to calculate the dragforce you have to take the integral of sigma(ij)n(j)dS where sigma(ij)=-p.delta(ij) + tau(ij) where p is the static pressure en tau is the shear stress.
when the simulation is converged in Fluent I do : Report-forces-print. I get several values (static pressure, viscous pressure, total pressure, and matching coefficients)
my question: should I just sum the static force and viscous force and multiply it with the surface dS of the cone, or do I have to consider the normal on the surface?
thx!
Old   March 17, 2008, 11:26
Default Re: drag of cone
Ebrahim
what do I have to take as area in Reference values? cause I'm working in 2D..
Does Fluent extrapolates the pressure from 2D to 3D to calculate the drag? in that case I can just take the area of a circle..
Old   March 19, 2008, 06:21
Necmi
Ä°f you are modelling a cone, may be it would be a better choice to use an axis and and an axisymetric solver instead of symmetry.
Pressure drag, friction drag and total drag? Cheng CFX 9 January 26, 2024 14:46
a cone injection,please help me!! satum FLUENT 0 July 2, 2008 03:38
computation of a cone Tobias Hoell FLUENT 0 August 15, 2006 04:08
Supersonic Cone Radwa FLUENT 0 June 20, 2006 19:16
cone angle jeffrey Siemens 0 May 30, 2006 13:46
